I'm currently putting together a TT swap for a 90 NA that I'm swapping to make a daily drifter/occasional road course car. I have everything ordered or on the way to build the motor up, including wiseco's, shotpeened rods, and a complete gasket/timing set/gates belts from COZ. The block has been leveled and deglazed, and heads been milled and all valves/stem guides replaced. So, the motor's going to be well sorted.
On the flip side, I'm lacking in empirical evidence for what I'm going to need for the boost side of the equation. So here's my questions:
- What turbos are in this ballpark? I know of the sport 500's, but I seem to recall that someone said these modded stock turbos were pretty inefficient. And jesus, can't a guy buy a turbo without a core charge? Yes, I realize that they need them to make the next set for the next guy, but as an NA swap fella, I have to go find some turbos or just eat the core charge, and that sucks.
- IC's - I've read the stock IC's are good for over 500, but they tend to heat soak. I was considering just picking up an FMIC with hardpipes.
- Tuning - There are chips everywhere...is it safe to assume the Z1/COZ/etc chips are conservatively tuned at this relatively low (not 800hp) hp level?
- Exhaust mani's - I know everyone salivates over the MSP mani's, but are they necessary at this level, or should I stick with stockers? Also, I could use some downpipe recommendations. FYI, the car has catback 2.5" exhaust.
Thanks in advance, guys.
Chris
