Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Sep 24, 2008 4:21 am
Forget the S14 turbo. The S15 turbo is by far superior, and easier to get ahold of (nobody sells the S14 T28 as a standalone, but plenty of people sell the S15 T28)
Get a nismo FPR. I wouldn't trust the megan unit to hold steady at 3 psi. However, unless your showing signs of over pressurization, I don't see a need for an adjustible FPR. So long as your pressure is staying in spec, there's no need for an adjuster. I've only used them to keep over zealous fuel systems in spec.
I've had some rough experiences with e-mance (poorly soldered daughter boards, etc). I would recommend Jim Wolf or Enthalpy.
I thought STi injectors were low impedence. You would have to convert the harness to include dropping resistors if that's the case.
A new oil pump is never a bad idea. However, unless your pump is showing signs of wear, I don't see the need to replace it. All of the pump failures I've seen over the years have been due to particles trying to flow through it (think chunks of metal and whatnot from busted parts).
With a good set of injectors, a Z MAF, and a good rom tune, you'll hit 320 or so easily on the S15 T28 I believe. I'm going this route right now, and I'm using 50 lb injectors, a JGY fuel rail, Z MAF, and JWT tune.
