Opinions about these wheels?
float_6969
Ok, so I'm not sure about these, but they seem too dang good to pass up. Here's the deal with my car. I like to keep the weight down (stripped interior) and I autocross during the spring/summer/fall, so I need to keep the wheel weights down also. At 1lb/inch, I think they are a pretty good wheel especially for the price, check it out;
HERE
rico05
Car: 1992 RMS13 w/ CA18DET
Not too bad. Pretty light too. I say go for em.
gabossie
Car: Your mom
Offset is pretty high, that's the only thing I can see wrong with them. +43, you'll need to run a pretty big spacer I would think, but ask one of the tire/wheel guys like Exar-Kun or the Tirerack guys.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Those wheels will fit just fine, my freind had a set of them.
stock offset is +40 and 6inch wide so the +43 offset and 7 inch wide rims will move the inner wheel lip 3mm + 1/2inch closer to the strut. I personally had a 7.5inch wide wheels with +45 offset on my s13 so i know it will fit.
gabossie
Car: Your mom
Ah, me be wrong then :D Nice to have someone smarter than me around. Maybe it's the fact that I have an S14 that clouded my vision :pface
Onizuka
Definatly not smarter, I was just stupid enough to buy honduh wheels for my car way back when, and they happend to just fit :D
Learning by experience sucks, thats why I like to help when I can.
Dori Dori
Car: Cars of course
And let me guess, you had stock (or at least type) struts too right? Not coilovers?
If you ever plan on getting coilovers in the future (or if you have them now), these will probably not work without spacers.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Dori Dori is 100% correct as usual. They will be fine with the stock setup but no room for coil overs.
Nismo_Freak
Car: 89 Nissan 240SX
16x7 w/ a 40 offset had about 3mm of clearance on my Tein HA setup
So anything above that is gonna need a spacer.
Exar-Kun
Car: 2005 350Z
spacer bad!money good.-chet
float_6969
Well I plan on getting Tein HE's. I'd like a 7.5" wheel, so do you think a +40 offeset would still clear? I also have to worry about my Z brakes too. I'd like something in a 17x7.5 +35 offset, but I don't know how easy that is going to be to find...
VitaminT
Car: 93 240sx SE
Tein says that you cannot run anything over a +38 with a 6.5" rim so I would guess no, but have never tried.
float_6969
Thanks, thats good info. I may have to look for something closer to a +30. I haven't decided on coilovers yet. I just dont know if I need the adjustable height or not...
Dori Dori
Car: Cars of course
float_6969 wrote:Well I plan on getting Tein HE's. I'd like a 7.5" wheel, so do you think a +40 offeset would still clear? I also have to worry about my Z brakes too. I'd like something in a 17x7.5 +35 offset, but I don't know how easy that is going to be to find...
Easy.
http://www.wheelchoice.com/wheel03.htm
Those black enkei's are pretty cheap too IIRC.
float_6969
I've got a 5 lug swap, needs to be less than 17lbs@17" too...
