MECPInstaller »
https://forums.nicoclub.com/mecpinstaller-u9687.html
Mon Jun 14, 2004 8:48 pm
yeah you should be good with a location around the ecu, follow the harness and look for the big rubber boot, might be able to get a cable through the boot, if not just look where it comes out in the engine bay and see if anythings close, if not drill away. One tip if you plan on doing acouple installs for you, your friends and whatnot, I'd definatly invest in a Unibit.
