blackpearl wrote: I know the s15 is the motor to get but i've seen it up to 3000 dollars...thats too much I would rather buy the rb motor and parts if I have to drop that much into an engine.
peace
you are better off getting the S13 Blacktop SR20DET for two important reasons
-1. high-port cylinder head. slap the S15 turbo on that engine and the S15 SR20DET wouldn't even matter anymore (of course, injectors, MAF, and ECU tune would be a must as well). the S15 VTC becomes a little wishy washy past the 350 mark, so S13 SRs are for power hungry drivers. the average is $1500-2500, which out of the $3000 you would have spent on an S15 SR, would be better allocated for injectors, MAF, ECU tuning, and a turbo. again depends on your budget
-2. its chassis specific. its simpler to bolt in and wire up. besides, the 6 speed is nothing special and your speedo would need to be modified to fit the transmission or you would need the S15 diff.
case in point : S13 SR20DETs are the more reasonable investments for your 180sx. S15s are more money for the same performance. if your pockets are deep, get it so you can brag to your friends. if performance is your forte, the S13 SR is your weapon of choice.
