Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Mon Jun 29, 2009 7:25 pm
Hmmm I'm not familiar with fully stand alone units, but there are members here that are so I'll let them chime in with help on that.
Check your AFR's, they should be a little under 12 in boost, and around 14.7 out of boost. Idle might be a little higher, but not too much higher. If your tuner knows what he is doing all he would have had to do is load stock KA fuel map and compensate for the injectors, and pull the timing a bit in boost. Hopefully you get it worked out though, it seems like you have put quite a bit of money into this project.
