NissanTurboSix wrote:To check rings:
Squirt a little oil in the spark plug holes. This will help the compression rings make a seal against the cylinder walls.
If this helps compression results, its the rings. If the results d o not improve, it could be the head gasket.
Wish I could do this test, but there is already oil on top of my pistons from the turbo seal going out on my turbo and shooting oil through out my system. My head is probably filled with oil, since I took off my top portion of my intake manifold and looked down the runners and there are puddles of oil in them.
I am just thinking by a head gasket going out, could it evenly have low compression (cyl 1-5 had 110 and then #6 was at 25psi) through the cylinders?......or is that most likely the rings/ring lands that could cause almost equally low compression?
Can a headgasket cause a sputtering almost knocking noise when blown?
