OPINION ON HKS TURBO
72nismo
Car: 510 / G35 / Murano
Turbo experts needed. What are your opinion on these turbo for a stock to semi built KA T ?
It will meet my power goals but just want to know what people think about it.
HKS GT2835 - 380/400/410 PS Output
>>>COMPRESSOR:
>>>-Wheel- 48/52/56 Trims -
>>>49.3/51.2/53.1 inducers / 71.1 Major
>>>-Housing- 70 Inlet / 50 Outlet - 0.50 A/R
>>>TURBINE:
>>>-Wheel- 84 Trim - 56.5 Major / 51.8 Exducer
>>>-Housing- GT25 inlet / Outlet spec:
>>>A/R 0.73,
WDRacing
Not worth the money....
It has a T2 flange so it will be a restriction at anything above say 9 psi. For the money there are tons of better choices. That would be a decent turbo if you were looking for instant but low boost. That thing should spool like nobodies business. But again, it's to small IMO.
WD
Chris28
Car: 92 s13 KA-T
What WD said. t3/t4 is the perfect size for a KA and will leave you with room to grow. Unless you are on a really tight budget, you should go with something bigger than a t2. If you're on a tight budget you really shouldn't be boosting a KA though haha.
Unless you're getting this turbo for less than $300 and will be happy with nothing more than 250hp, save up and go t3.
WDRacing
The HKS turbo's are wicked expensive...way more money then I'd ever dish out for a turbo.
72nismo
Great. Thanks for the opinions. :bigthumb:
