Loofee95SE wrote:Cool thanks RMiller, I was actually, waitting for ur reply, cos I know u have 1 on ur CA, but I have no way of talking to u. how i sthe performance gain?? I've got Fc 460cc injectors, ready to go in @ the same time, with new water pump and thermostat. C
No problem. Performance is like f s t caz said, but I don't feel it pull hard after about 5500. I mean, it's accelerating, but it feels like running a v8 past about 4500. I'm running 1 bar right now, and it's hard to say because it throws me back in my seat, but I think I get full boost around 3500-3800 rpm in 1st, a little sooner in higher gears. It's really strong from 4500-5500, and I'm most impressed with acceleration in 3rd, 4th, 5th gear. It just keeps pulling, it's amazing. On the freeway in 5th, I accelerate faster than my '00 mustang gt at stock boost.
This T28 isn't too big for the CA, but if you have an equal choice between it and an s14/15 t28, I would get the latter. Still, it will build boost smoothly up until about 7 psi, then shoot up to whatever you set the boost at. So about .1 bar at 2300, .2 at 2500, .3 at 3000, .4 at 3500 (it changes depending on what I set my boost at, so I don't know for sure, that's why there may be discrepancies between my figures here and above).
You have to re-clock the compressor. I had to cut my heat shield to get it to fit, but it's not a big deal. You have to mess with the wastegate bracket so that when it is re-clocked it will work properly(see above post). To do this, you basically cut out a triangle from part of the bracket, then close the gap and weld it. You'll know exactly what I mean when you clock it to the correct position. I got away without welding it because my brother drilled a couple holes and added spacers in such a way that positions it where it needs to be, but welding is easier and probably more reliable.
What I would do now for the turbo outlet is make a 6 bolt flange that lets you rotate the outlet pipe 20 degrees (estimate) so you don't need to buy a silicone 90 degree coupler or a fat radiator hose. Just get a 1/4 inch aluminum sheet, match it to the turbo outlet flange and drill 3 holes, then position the outlet pipe where it needs to be and drill another 3 holes. Then cut ~2 inch hole to match the outlet size and you'll be good to go. Do what f s t caz did for the inlet.
I recommend getting the injectors tested and cleaned in necessary. There's a place that does it for pretty cheap, and it looks very professional, but I forgot the name.
http://www.witchhunter.com/ There's one place, $12 per injector. I think it would make a noticeable difference with most older injectors, like yours and mine (dsm 450's). I talk too much.
