Opinion of Nistune
zache803
Car: Ca18det powered 240sx
Hey all, i was thinking about getting Nistune in the next month or so, and i was wondering if some of you who use it could tell me some positives and negatives on it, would you recommend it to someone else, and how easy it is to tune with this program.
Thanks in advance,
Zach
21FOX21
I thinnk that it is great. I'm making pretty good horespower, it's fairly easy to tune, good support for it. The only things that I don't like it that their is no option to use a map sensor right now and there is no launch control.
Cams
Car: 1993 Nissan 200sx CA18(DET) RS13
2002 Mitsubishi Airtrek JDM 4G63T (wife)
2013 Scion FR-S
2016 Infiniti QX50
Can you post further about your setup?
How did you get 330whp? And how did you do 12.x with a T25? Id guess those are 2 different stages of your engine, right?
Just curious.
jey_253
Car: 1990 S13 Silvia Conversion Rb25det
I have to bump for nistune also. just from a street fuel and ignition tune i was out running my friends built gsx on a 57 trim abd 15lbs with just my sr t25 on ~10lbs
zache803
when i order it which one should i get and are there any other things i should buy for it?
Buddyworm
Everything you need to know is on their website dude. It tells you which board you need for your ecu and anything else.
jt15833
Car: 95' 240SX
i have it and think its a great product. CA18DET uses Type 1 Rev 3 board, has a straight USB hookup and has nissan consult.
I have an Lm-1 wideband and with both the ecu and wideband hooked to my laptop i can do street runs or dyno runs and log many parameters such as rpm, speed, maf, etc alongside wideband AFR.
I think it is a great choice for a plug and play management that allows modifying fuel maps, timing, and rev/speed limiter.
I bought an ECU in AU and had them install the board. Was about $550 shipped to me.
Good luck, I will probably post screen shots of the software when I get some more time.
mbmbmb23
Do you have your LM-1 O2 sensor permanently installed or do you take it out after tuning? If its permanently installed, do you know how long it will last until it burns out?
-m
