Opininons With std HG and boost
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
c-west
Car: Datsun 240z
I,m going to boost my vh 41 with around 1,5-1,7bar from my 4094r.
Have checked the std nissan headgasket against the rb26, sr20 and ca18,
-it is identical.
My plan is to run the std HG with arp headbolts and hope it will take it.
I have 8.5-1 cp pistons ready to go in it.
Nizpro says that they use the std gasket with their builds, but I dont know if the block is o-ringed...
I have run 1,7bar on a completely stock gti-r sr20 engine for about 30 000km,s without issues,
so I think it should work.
What do you guys think?
Is there any uprated headgaskets on the market avaliable for the JDM vh41?
Carl H
as long as you keep detonation in check, have a good tune, and run good quality fuel you should be just fine.
I've pushed as much as 26psi thru my rb30 on a stock rb26 headgasket and arp head studs.
stock gasket is well designed and can take abuse, but a bad tune will do it in with the quickness.
Return to “VH45DE / VK45DE / VK56DE Forum”
