Operation rod knock
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gs14racer
T45
Car: King Kong powered Z32
Ah, oval ports are for sissies. What's the plan?
gs14racer
Well......
Since I have a v8 I think I'll go back to my domestic days and do the usual.
More displacementbigger valvesand cam
I will not be doing the rebuild im gonna give it to Mazworx.
Do you guys know of any other pistons that fit in the hole its gonna stat na so close to stock compression is ok.
Also what is the max the stock block can be bored before sleeving is required?
Thanks guys.
Reno
Car: 89 S13, boosted.. RAWR..
hmm dunno but i think there a stroker kit from JDMland i think its a 5.1 or a 5.0
gs14racer
yea i saw something like that not to long ago.
But judging from the size of the bore spacing i would think it could be done with bore alone. It would probably need a resleeve but i think its possible.
Q45tech
10% more displacement is sure an expensive way to get 10-12% more power.
defrag010
I've re-sleeved a VH block out to 3.780" bore. There is alot of aluminum around the stock iron liners so you can open the bore up quite a bit with some new liners.What I'm doing now to my extra VH block is sleeving the bore down with 1/4" iron sleeves to 3.625" bore, and using probe part number 14434-073 with 6" chevy rods. ends up a little smaller than stock, but uses off the shelf forged parts.
If you want some larger valves, I made a thread here about a year ago where I listed the part numbers of valves and guides, and what you need to do to make them fit in a vh head. I think they were 3mm bigger exhaust heads and 2mm bigger intake heads.
Modified by defrag010 at 7:59 PM 11/14/2007
canadiandrifter240sx
If I am not mistaken Top Secret, the very popular tuning shop in Japan used VQ35 pistons in there Vkdett that pushes 700hp . Not sure if the bore is the same a the vh though.
Base: Nissan Skyline (CV35)Engine: VK45 V8 Twin Turbo SPLDrivetrain: 6speed Getrag, ORC, RWDOutput: 720ps /7000rpmNotes: TAS 05 - Best Tuned CarMax Power 05 - Best Tuned Car341km/h Autobahn Attack
canadiandrifter240sx wrote:If I am not mistaken Top Secret, the very popular tuning shop in Japan used VQ35 pistons in there Vkdett that pushes 700hp . Not sure if the bore is the same a the vh though.
My mistake they were VQ30 rods and pistons.
here is the article from super street.
http://www.superstreetonline.c....html
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Any clues/ideas what caused that head gasket to get sucked in? Did it get run hot?
tmorgan4
Car: 2000 Nissan Pathfinder
Hey Jerry...want to sell me a few easy access parts off the old one??? I need the crank bolt and the little access cover that sits on the lower timing cover, passenger side.
gs14racer
Id be happy to get you those parts as soon as I get my car back. Like I said in the other thread the car is at Mazworx getting the roll bar put in so its like 250 miles from me right now LOL.
Hey defrag shoot me an email I'd like to bounce a couple ideas off you and maybe we can do some buisness
My email is [email protected]
gs14racer
ScottJackson wrote:Any clues/ideas what caused that head gasket to get sucked in? Did it get run hot?
I have no clue about the cars history just know that it started and held good idle. Thats it lol.
It may have happenend when i pulled thr head i dont know.
ScottJackson
Looks like it was run for at least some time after the sealing ring got sucked in. I'd say it probably got rather hot at some point, warped a bit, and the loss of clamping force allowed the head gasket ring to get pulled in the chamber.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
canadiandrifter240sx wrote:My mistake they were VQ30 rods and pistons.
I wonder how accurate that info is?
I have VQ30DET piston compression height as 30.4 (not sure on reliability of this info, but it was on a piston dimensions chart), and VQ30 rod length as 147.65
So if we go:30.4 + 147.65 + (82.7 / 2) = 219.4
Assuming the piston info is accurate, we can see the piston would have 0.95mm deck clearance at TDC, when installed in a VH45DE.
This obviously isn't fine, so I did a little reverse investigation and found the VQ30 deck height is reportedly 215mm, so here we go:215 - (73.3 / 2) - 147.65 = 30.7
So if the VQ30 pistons actually sit flush with the deck in that motor, then theoretically the compression height is 30.7mm, which gives us a new installed height of 219.7mm, and a deck clearance of 0.65mm.
Anyone care to interject/confirm/deny/speculate on the above?
ScottJackson
Hmmm, seems fine to me. You'd lose some quench if you don't mill the decks or use thin head gaskets, but guys that run high octane gas and boost often don't care much about quench anyway. Will the VQ rods match up fine to the VH crank?
Mettler
Unfortunately, based on what I've read, the VQ30 conrods are 48mm at the big end, which renders them pretty useless.... unless they're meaty enough to remove like 3.5mm worth of material off the radius & still have at least the same thickness as the VH rods (unlikely).
I'm also investigating another avenue for doing this... have e-mailed Jerry with questions.
gs14racer
what about vq35de pistons
95.5 mm
29.64 compression height
gs14racer
does anybody know what kind of effect sitting the piston 1.2mm (.047 thou) further up in the cylnder bore would have to compression or piston to valve clearance. ?
Return to “VH45DE / VK45DE / VK56DE Forum”
