FukinG37S wrote:Wow.
Hijacker wrote:Dammit. Now I have to mop up drool from my desk!
Those look to be MB Weapons.S13AL wrote:What wheel is that?
First off I know it's more than I need, second it's an s14 lol can u guys not see the avatar lol, and surprisingly enough these calipers don't weigh much, about as much as the iron z32tts did, the rotor is what weighs a ton, but let's be honest u won't be able to tell a difference other than the fact they're goin to look fantastic and be the last brake upgrade I do...and this car is only goin to see track mostly now.PapaSmurf2k3 wrote:Yeah that's more braking power than you'll ever need, unless you're towing something with your S13. Its probably actually going to hurt you a little bit... adding massive unsprung weight.
x2. While they may look good, I would worry about them locking up if you stab the brakes to hard.PapaSmurf2k3 wrote:Yeah that's more braking power than you'll ever need, unless you're towing something with your S13. Its probably actually going to hurt you a little bit... adding massive unsprung weight.
exactly why you don't stab the brakes too hard lol...plus tires have a big factor in grip1KleenS13 wrote:x2. While they may look good, I would worry about them locking up if you stab the brakes to hard.PapaSmurf2k3 wrote:Yeah that's more braking power than you'll ever need, unless you're towing something with your S13. Its probably actually going to hurt you a little bit... adding massive unsprung weight.
