Opening the top with door request switch?
Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
BadDogi
Car: 2010 Infiniti G37 Convertible
Has anyone opened the hardtop using the door request switch? According to the manual you can, but I was unable to. Here is what the manual says:
“Opening The Hardtop Using the Door Handle Request Switches Press and hold either the driver’s or passenger’s side door Request Switch until the hardtop is open completely. This operation cannot close the hardtop.
Note: Requires the Intelligent Key to be on “your person,” within the operating range for the lock/unlock operation to function.”
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
On my 2010 model. If I hold the black button on the outside of the drivers door the top will Start going down. You do not want to do this too many times without having the car running because it will drain the battery p. Sometimes taking the top down 2 times without the car running will drain the car enough to to keep it from starting.
I don't know if the 2009 models can do this. Go give it a try. Just not more than once
BadDogi
I have a 2010, I tried it with the car running, it did not work. I will try again and see.
Fezzik
I think the door one has to be done with the car off. Give it a try
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
BadDogi wrote:I have a 2010, I tried it with the car running, it did not work. I will try again and see.
Welcome :cheers:
Is the separator plate in place?
How many beeps do you hear when you press the button.
Opening the roof with the drivers' request switch is indeed possible if you meet all of the pre conditions.
ALWAYS check the truck before opening the top.
bschurr
Car: 2009 G37S 6MT Conv
Fezzik wrote: I don't know if the 2009 models can do this. Go give it a try. Just not more than once
Yup - this is a standard feature on the 2009 Verts too!
i use it all the time...
Cobra_Kai_84
Car: 2009 G37S convertible - Athens Blue/Graphite, Premium, Sport, Nav, rear deck spoiler
I do it occasionally when I want to watch the roof do its thing, or showing it off to someone who hasn't seen it in action. But 9 times out of 10 I do it inside after the car is already on. Never had a battery issue.
Return to “G37 Convertible Forum”
