Opening the bellhousing
Lepchitz1
Car: Cars, and LESBIANS!!!
How do you open (split) the bellhousing from the other half?? Im trying to figure out how to re-allign the "shifter forks", that russ told me I had to do cause it was a common problem that happens to a transmission during shipping pls help asap!!!
mattback
Car: being a big f'ng ricer
umm.
ok theres like bolts.and then there is that inside cover thing. it has the nut on it that the clutch fork revolves on. theres like 6 bolts that hold that sob on after that you have to get snap ring pliers to get hte c clips off. and then it should come out with persuasion.
