240kid wrote:i dont know if this will help, but here it is anywayhttp://www.nissaninfiniticlub....page=
Actually, there should be another page that shows you how the lines for the AIV are run. See if you can scan that one and up load it.
If I recall, there should be a line running from manifold to the control solenoid. If you disconnected that and left it open, you'll have a vacuum leak in the manifold. It probably won't drop it a huge amount, but it'll still be more than you want. The other lines I believe run from the air intake to the AIV and then to the exhaust. I think the valve is normally closed, so if the control is disconnected the valve will stay shut, but someone can verify that.
