Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Wed Jun 16, 2004 5:23 am
The hole is probably for the AIV, which was removed maybe. Its not important to your purposes.
Tell me, under your hood, is there a black plastic box to the right of your engine sort of hovering there? It's cube-like with rounded edges. If not, then thats where the pipe from that hole used to go. I think it is for the PAIR valve which turns on the device.
No matter if its before or after the air sensor, you should plug it with something solid. Go to your hardware store and look for a PVC pipe end cap (in the plumbing section) that might fit it
