blackwdl »
https://forums.nicoclub.com/blackwdl-u26168.html
Mon May 21, 2012 1:52 pm
Hate to tell you, but from everything I have seen, you would need the entire transmission. The bearing on the lsd diff is much larger on the drivers side...
You might be able to get away with using the engine side of the transmission bell housing, but still might require machine work.
