rschwalbe »
https://forums.nicoclub.com/rschwalbe-u4143.html
Sat Jan 25, 2003 9:45 pm
I think in his #2 above, he is talking about the fuel rail (at least that is what it sounds like to me). Should be 2 bolts holding on the fuel rail and that needs to come off. Pull the injector out, remove the wiring, check your O-rings and make sure they are OK, if not I would get the replacements at Nissan and not a parts store (I have bought 2 kits at 2 different parts stores and they do not fit right). Then put everything back together the same way you took it apart. Make sure you DO NOT tighten the fuel rail bolts too tight as they will snap the heads off (I know this from experience!).
Good luck.
