Open bov
F3600
Hey i was wondering if its bad to run my car with an open bov ? The bov is working nice(dsm bov) i have no idle problem... sometime the idle drop but stabilize at 800.. I would like some input on the subject
thx :)
f s t caz
Car: VG30ET D21 Extended Cab Pickup
my HKS will cause a backfire "pop" that i've only noticed when taking the car relatively high in the rev's, and shifting slowly to the next gear. Most frequent during 3rd-4th. Never had it cut off on me as a result though.
float_6969
that sound is that awesome fire ball you get out of the exhaust in between shifts with an atmo bov.
f s t caz
float_6969 wrote:that sound is that awesome fire ball you get out of the exhaust in between shifts with an atmo bov.
stock piping, so i highly doubt that it'd be out the exhaust. one day, maybe i'll blow apart my muffler... :(
fanta
If you're still running the MAF, you will run rich at times, as the air you expend has already been measured for a set amount of fuel. You may experience stumbling in between shifts, a low or erratic idle with an occasional stall, or nothing at all. All cars are different and take the dump in their own way.
I would crush the DSM bov to ensure that it does not leak at idle. Bumping up the idle a bit would ameliorate some idle problems, same with an adjustment in shifting/footwork.
Projex240
Car: Dogs , My RIDE
alot of times, people will change their maf setup to blow through.The maf reeads air entering the turbo, and calcualtes the fuel needed to compensate for all that air. So when you shift, the air is realeased, but already has been metered by the maf. All of that fuel is still begin injected into the motor. SO by running a blow through maf, you can more accurately measure the air entering the motor, and take car of that rich situation. Therefore--loud sso sexy BOV sound--and no more poppinh, and richness. You get that blackness on teh back bumper over the muffler yet? If not--you will when you put an exhuats on it.
-Josh
nab911
Car: 93 Nissan 240SX SE
When you say blow though, do you mean the maf on the intercooler piping as opposed to turbo intake? Someone was arguing how that doesnt do anything and i still dont think im too sure on how it would change it, because any air that goes through the IC piping, has to come in through the front of the turbo/maf.
Projex240
Car: Dogs , My RIDE
it doesnt really "change" it, and it doesnt make any power--well none that anyone has proven.All it does when moved to the i.c piping no closer than any bend 6 inches close--and 8 inches fromt eh TB, is measure th air entering the motor rather than entering the turbo. When the air eneters the turbo-it passes throught the maf (ex 10lbs of air)that calcs teh fuel mixture(x amount of fuel). when you blow off, the air escapes into the atmosphere(now only 2 lbs remainthe other 8lbs got blown off into the atmos.)-but the fuel that was calced to be injected still gets into the moto( all x amount of it) which equals too much fuel not enough air(remember--its blown off now) this makes the car rich and backfire between shifts. I have seen it smooth cars out that run open atmoshperic blow off valves, but not mafs like the effect. most just do fine, and you can continue to run open BOV with no ill effects.This isnt really a performance gain, just to be able to run open BOV for sound. SOme say its more accurate because it actually reads the air going into the motor rather than into the turbo--make sense to me--ill be switching my ka over to it shortly.
rico05
Car: 1992 RMS13 w/ CA18DET
Open BOV + L-Jetro = Fouled plugs and running too rich. Seriously, just recurc it. You'll get better boost response and better MPG.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
or you could just be like me and change your plugs with your oil! my car just eats plugs.
and not to jack the thread, but does anyone else have the problem of your ignition putting out so much current that it turns the tops of the plugs a dark, sort of golden brown instead of white?
- tim
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
your plugs are supposed to be that color.
white means your running lean.
BLACK is rich.
no reason to replace golden brown plugs.
IvoryJ30t
a blow thru maf is placed after the IC before the throttle body.
you place the BOV between the compressor and the IC.
when the BOV vents, the escaping air hasent been metered, so the car will run correctly.
it doesnt gain power, its just so that you can run an open BOV without dumping metered air. constantly dumping metered air will cause carbon buildup and foul plugs ect...
