OP lowered car, wheels now rubbing fenders, looking for advise
MikeyKaVert
Car: 1992 Nissan 240sx Vert
ok so i got tein coilovers for my 240 and put them on. i have a camber kit on it too. well the thing is i lowered it and its rubbing so i'd like some input on whether i should just leave it (its not rubbing TOO bad), OR just raise it, get some new wheels, and camber it out. as of now its my DD, but i plan on DDing it and doing some weekend drifting. any ideas?Thanks...
s14derrick
Car: 1995 nissan 240sx
where is it rubbing? fender? show us some pics and mroe details please
MikeyKaVert
well my rear fenders are rolled, but not the front. it's not rubbing the fenders at all, just the wheel well. oh and i fogot to mention that there are some wires running from the inside of the car to the engine bay, and they run through the wheel well and the wheel is starting to fray them. is there any way to run them under the fender but not through the wheel well? ill put up pics in a minute, lemme go take some...
S13Joe
Car: 92 Coupe
RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY.
s14derrick
DirtyGhettoKids wrote:RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY. RELOCATE THAT HARNESS IMMEDIATELY.
do that asap. once that harness is damaged you are in for one helluva mess. and if its on the inner side maybe you need some spacers
ronnie_angel
Car: 1993 240sx
do nothing...they're just wires
MikeyKaVert
ok i took some pictures. for some reason my left side is rubbing more so...here they are:left wheelright wheel
n240sxfnatic
Relocate harness, Im guessing you have terrible offset wheels to?
Jdmstyles
Car: My S13 took a crap on me.
Bad offset wheels that are bigger than it should be will rub once lowered.
If you have the funds, get new wheels, buy smaller tires, or get spacers. I don't think there's any other way around it.
s14derrick
def relocate the harness. show us some pics of the car it self. maybe it could use spacers to fix the rub and the overall apearence
simmode1
Car: Red '95 S14
Oh god... the harness! Don't be Clawhammer part II... that was quite a clusterphuck for that guy...
MikeyKaVert
yeah sorry but i have NO IDEA what the offset is. it came with the wheels that are on it now.here it is...
Modified by MikeyKaVert at 8:43 PM 8/6/2009
cbt240sx
Car: 1990 Nissan 240sx
Offset kinda looks like +40 or +45......idk. Spacers?
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
looking like 40 4 judging by the rim.. style.
s14derrick
can use spacers. they would make the wheels more flush while brining them away from he inner fender. do that or get better wheels
Elbowblk
Car: 95 240sx
as everyone said. relocate asap! or else you'll have problems
either move them higher in the fender or do it the right way, through the engine bay.
pj
Car: 95 s14
all i did was remove the fender, hammer the body under it down a bit and made a nice spot for the harness to lay in, then used some small gauge wire i had laying around to tie it snugly in place out of harms way.you should do the same, but before tthat make absolutely sure all wires are intact and none have worn through anywhere.you should be good to go then.
Car: 240sx
raise it up a bit and get your fender liners back on
Chris28
Car: 92 s13 KA-T
The easiest option would be to raise it. Is there part where it rubbed through your paint and now it's rusting there? That'd ridiculous.
As everyone said, relocate your harness immediately.
MikeyKaVert
Well see, i already thought about spacers (which i will eventually get), but the rubbing is occuring at the top of the wheel and not the inner side. UNLESS the ppl that commented on spacers meant, move the wheel out with them and move the harness in more...i tried to figure it out today but until i get it off of the ramps, i wont be able to get the wheel off to try for real. but anyway thanks all of you for your help. tomorrow when i get home from school ill get it down (because its FINALLY fixed!) and give it a go. ill be sure to put up some pics too...thanks.
n240sxfnatic
2056515 wrote:get your fender liners back on
pointless
