oops...
gumby
Car: '89 240sx sohc
Being a retard I tried to pull out the stock manifold without disconnecting the steering shaft and it dropped 6" so that the aiv bung landed on the U joint.
:eek:
How bad it that? Do those things ever need to be replaced? How do I drain the power steering fluid and disconnect the shaft?
FSM is on the way. i just got impatient.
Dattebayo
why dont you download the FSM? It only takes a few minutes, even if you have dial-up. What U joint are you speaking of?
gumby
Car: '89 240sx sohc
well i downloaded some sort of service manual but its not the FSM. I'll try the '91-'93 FSM steering might be identical to '90. I was just hoping someone else might've done it before and offer a few pointers. I have a diagram so I'll work it out tommorrow.
thanks
navysnail
if it still turns, dont worry about it, those things are pretty simple ( robust), so if it still turns smoothly, its fine
gumby
Car: '89 240sx sohc
o-tay:)
Dattebayo
Do a search for SOHC FSM, and it will come up. It was put up just yeasterday...
gumby
Car: '89 240sx sohc
thats the one but it doesnt seem to be it. has info on other models. Definitely an edge over chiltons anyhow.
