centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Dec 17, 2007 10:26 am
Two part question.1. I have a 1997 transmission that came with my S14 and I have an older, maybe 1991 transmission from an S13 that I was using for a temporary replacement. Both are 5-speeds. Anyway, the throw out (release) bearing for each, gets pressed onto a bearing sleeve (release sleeve). I have two, each has a different height (maybe a 1/4" difference). The taller of the two appears to have been cast differntly and has a seam for each half. The shorter one has no casting seems. Which one should I be using in the S14 as I see a potential issue with clutch release.
2. I was taking apart the S14 transmission for a rebuild and carelessly let the sychro inserts fall out. There are three types, one set of 3 are like springs, another set are solid little metal guys with a groove cut into the bottom from end to end and the third set of 3 are solid metal guys with a groove cut into the bottom that stops short of the ends. Who knows where each set goes? I can tell where the spring one's go by the picture, but the solid types look very similar except one is about 1/2 mm longer that the other and the bottom grooves are slightly different so where do those go?
