only one high beam works, checked fuses, changed bulbs.......
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
about a month ago my passenger side high beam went out. i thought it was just the bulb, so when i got around to getting a new bulb i found that it still does not work. i have looked at all the fuses and cant find one for just the brights, the ones for the headlights are fine and i have checked quite a few other fuses too. has anyone seen this before?
johnnyknoxvillej
Car: 89 sr
Put your high beams on and get out your voltmeter and see if you have power going to it, i would say you have a ground there is only 1 fuse for the entire headlight operation.
