SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Mon May 01, 2006 2:43 pm
Compare the wire colors to this ECU pinout. If they match the list on the right you need a 62, 63, E5 or E6 ECU. If they match the wire colors on the left you need a J4 ECU.
Rather than wasting a bunch of time looking at all the wires look at the coilapack wires in particular. They are one of the only main differences between the ECU's.
For instance notice how the first cylinder wire matches on both lists but does not match the other coilpacks. This is why crossing ECU's and harness's can lead to only coilpack #1 firing.
