240_SeX »
https://forums.nicoclub.com/240-sex-u88915.html
Wed Mar 18, 2009 2:11 am
I will warn you before i post this, it can be very dangerous....
Disconnect the vacuum hose from the wastegate and plug/clamp the hose (prevent vacuum leak) and go for a VERY SHORT ride,
While driving, very slowly roll into boost and watch the boost gauge closely. If you just go out and hammer on it you could spike to 30psi and melt some pistons.
So roll into boost with the wastegate disconnected and see if you boost more than 7psi.
