Only if you reall know the Q inside and out
phats69
Car: 1998 infiniti q45
here is the deal, i got some drilled slotted rotors and 2 front struts put on the car today. The mechanic said everything went well until he took the car for a test drive. He saod when he got to a red light the TCS ABS and check engine light came on. he took it back to the shop and hooked the car up to the code reader he got these codes
p0120, p1705, and p1125My question is what are these codes and how to remedy the problem
goody90q45
Car: 1992 Infiniti Q45 (sold)
P0120- TP (Throttle position) sensorP1125- Tandem TP SensorP1705- TP Sensor A/T
It looks like you may have a problem with one of the throttle position sensors. It's probably not related to the suspension work you had done.
superuber
Seems odd that they came on though. He was under the hood for the struts...........may have jarred something. Should have done all struts.
superuber
also, as far as the abs and tcs lights those are related to where he was working. Plus one or more of the obdII codes may have already been stored.
phats69
since this post the TCS ABS lights have disappeared and just the check engine light is on. Any ideas?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
phats69 wrote:since this post .... just the check engine light is on. Any ideas?
What code is stored? Did he fubar the ABS sensor?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
My guess is he budged a connector or somthing while he was under the hood.
