New pump installed, started up fine, went for a test drive, up to temp & nailed it, too fast for a drop to 1st gear so I waited patiently for the power to turn on......hit 4000 rpm & subsequently a limp mode w/check engine light.
WTF?
Pulled the code, 11, CAS. Restarted the car & barely touched the CAS harness, it shut off. Noticed the CAS is directly above the oil filter. A-HA! :rolleyes I must have kissed the connector with the back of my hand as I was breaking the filter loose from above, just enough to loosen a female spade or two on the plug.
Adjusted the tension on the spades, now with a nice tight fit, all is well with the world again.
The pump was going bad & it feels a lot better, the car was just trying to tell me to change it now.
AZ, the A Body is a 72 GS 455, stock block, .030 over forged pistons, nodular iron crank, stock rods, but TA performance Stage I aluminum heads, TA shaft mounted rollers, Edelbrock Performer intake (to retain the ram air) Demon carb, TA front cover, with revised oil pump & water passages, MSD dist/ignition, Hooker Super Comps with TorqueTech 3" mandrel bent ceramic coated exhaust (through the N-25 (?) rear bumper), TH400 with GearVendors under/overdrive & PI converter, Global West tubular (*negative*
camber) suspension, 100% suspension resto, rear disc conversion, Hotchkis RLCA's, Koni's, lift bars, TA rear cover, Weld Rodlite 18x8's, Michelin Pilot sports, full under hood wiring restoration, PS, AC, PW, PDL. Currently white/green stripe, soon to be yellow/black (the way it came).
I can post pics tomorrow if you'd like, I had a 71 SS454 Monte Carlo when I was in high school, A bodies will always have a soft spot in my heart, too. It's so nice to be a part of a forum where there are those that see beyond whatever marque they happen to be driving at the time and appreciate others for what they are.
PS, you're dating yourself (and me) with the World of Wheels show.
