only hot or cold air....nothing in between
suzook
2002 pathy with factory nav. I only get extremely hot or cold air blowing. Nothing in between. Its very hot with anything above 66....turn it to 65....and its cold. Where should I start?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Park with the front end in direct sunlight, then run the self-diagnosis procedure described on page HA-45 of the factory service manual and report your results.
suzook
I'll give it a shot tomorrow. Thanks
suzook
Towncivilian wrote:Park with the front end in direct sunlight, then run the self-diagnosis procedure described on page HA-45 of the factory service manual and report your results.
Pulled a code 22....interior temp sensor....checked it out...the wire made its way out!..Plugged in WALLA! Shes working properly :woot: ! Thanks.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
Have a picture or description of that plug?
Ive seen this problem more than once posted
suzook
CanuckQx4 wrote:Have a picture or description of that plug?
Unfortunately I dont. It's right behind the drivers side knee panel. There is a sensor with plug...and a tube that connects to the Lil vent.
Towncivilian
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Is this sensor on all R50's, or just on those with auto climate control?
Towncivilian
Only on those with climate control I believe. All dashboards have the little vent, as far as I know. I'll shine a flashlight through the vent at some point to confirm manual HVAC control equipped models don't have it.
