Thanks! I will be placing my order soon. Are those the newer version of the lower guides that come with the 3 mounting bolts? Maybe a typo, but seems like the oil pump components (Drive gear, gear set, pump cover, gasket, and regulator valve) come out closer to $75 than $195. I couldn't find any price for an oil pump though.MidwayParts wrote:13085-1E401 GUIDE $12.8413091-53F01 GUIDE $67.8913070-AD504 TENS $51.1513028-5B600 CHAIN $41.8613028-53F11 CHAIN $28.6513070-4E102 TENS $51.1521010-40F27 WATER PUMP $62.4012279-5L310 REAR SEAL $13.5913510-53J11 FRONT SEAL $4.8413500-70F11 OIL PUMP $195.89
I remember reading a post that said the lower guides were re-designed, and you need to get the three bolts with the guides since the old hardware does not match up with the new design.MidwayParts wrote:The pump is apart of the front cover. And which bolts are you talking about?
+1, i need the seal that goes around the actual glass it'self.Turbon8er wrote:Hey busy Mike! how much for the Sunroof SEAL (attaches to glass) on a 93 240 hatch w/ flip top (man) roof? i searched but couldn't figure out which item # it was...Thanks!
