ONLY EDUCATED PERSONS ALLOWED IN THIS THREAD, PLEASE! J30/VG30DETT ?...
S13CoupeLuvr
Car: '93 240sx SR20 dark green hatch
'95 Maxima white 5spd
What's up fellas. I'm purchasing a '93 J30t (black on black with new timing chain, 110,XXX miles) as my daily driver. I really want to swap the VG30DETT into the car, and I would love to have the 5-speed from the Z, too, but I hear this is asking too much of the JPY32 chassis. I'm going to get underneath my friend's TT Z soon and do some measurements and compare the findings to the J (this will be my second J and my fifth Nissan) but I'd like to hear some input on this subject, anyway. Can the twin turbo swap be done? Even if I must keep it in automatic form, I still want to do this swap. Help me, please! There is almost no info on the Leopard 'round these parts! Thanks for the replies that will surely come...
Megaseth
Car: 2002 Pathfinder SE
Im not sure the TT would fit, but if im not mistaken, the VG30DET from the JDM leopard should bolt in no problem. the piping would be much easier to fit since its stock-like. im not sure about the transmission though, but im sure a 5spd swap would be no trouble.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Apparently it won't fit. I asked about this for my J30 Maxima, which everyone thought was an Infiniti J30, and they told me it wouldn't fit in the Infiniti. But, yes, as Megaseth said, the VG30DET from the Leopard should fit fine.
Is the J30 front or rear wheel drive? You'd have to use the transmission from a J30 or a third or second gen Maxima if its front drive, as the Z is rear drive.
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Mr. Doom the J30 is indeed Rear Wheel Drive. And though it looks like an over grown altima IMO it is a really sweet car when you get to looking at it.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I've always liked the car, I just don't know a lot about it. I like the looks, aside from the trunk and taillights. I like it even more knowing it's rear wheel drive.
SeVa-S13
Car: '05 GTO 6spd
The I30's were the Maximas, not J.
krazy skwerel
2005 Honda Accord
With the right spoiler I think the rear end could be boxed up enouh to make it look very nice.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
SeVa-S13 wrote:The I30's were the Maximas, not J.
No, J30 is the chassis designation for the third gen Maxima, it has NOTHING to do with Infiniti. See what I mean about that thread confusing everyone?
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
here we go again.
the vg30dett will bolt into the J30. you then have to wire the car and mount the intercoolers.
the vg30dett comes in auto or manual, so you have a choice. if you go manual, your gonna need to ditch the cruise control, becuase the actuator sits right where the clutch master cylinder will.
this swap has been done before, and i cant imagine it being that difficult. you will need custom exhaust though.
ive been researching this for a LONG time. i originally wanted an rb26, but then i realized that the amount of money that the rb26 would cost equals a built twin turbo vh45 with a custom bellhousing for a T56 trans.
if you go manual, you will need to tighten up the suspension. not cheap [requires custom parts]
as long as you are capable, this swap should be no problem.
BTW, the VG30DET from japan will not work too well. the single turbo is posistioned on the drivers side, where the steering shaft will most likely interfere. [remember, RHD in japan]
Megaseth
i didnt even take into consideration the turbo placement on the DET...nuts...couldnt you just convert it, or rather move it to the other side? i guess with all the work in doing that you might as well just drop a DETT in.
