stiergott »
https://forums.nicoclub.com/stiergott-u17357.html
Sat Aug 27, 2005 2:37 pm
you j30 guys are tryin to make the motor fit in the car. since you havent done anything that hasnt been done to death you dont know this yet, so i'll tell you. you have to make the car fit around the motor. if you drop an rb20 into a s13 you dont shave the intake manifold you cut the supports outta the hood. put a rb26 in a miata you hack away at the miata. put a redtop into an e30 you gotta change the bmw crossmember. get the idea?
secondly you are way way off on the pricing, unless your adding power. a jdm z32 front cut is $2300 with all the sheet metal on it. figure $100 in trips to autozone, lowes, and the walmart. if the clutch is bad that thing is like $450 for a 600ftlb drag clutch. and a driveshaft is $345 plus tax, just got one done for my rb25.
if you buy a front clip you will get everything you need to do the swap. its all there from the clutch crap, intercoolers, shifter, crossmembers, brakes, and lsd. theres nothing else you really have to have, maybe a fuel pump but im not there yet.
im leaning away from this conversion at the moment. i love the vg, i think its a great motor. im just not a fan of the j30, the car deosnt really do it for me. i would rather spend the money and do a gs300 2jz aristo conversion and go supra hunting.
