420sxse »
https://forums.nicoclub.com/420sxse-u27656.html
Sun Apr 24, 2005 8:26 am
>Try the solid blue wire, it should work beautifully.My bad, I wasn't clear. It IS the solid blue one that I'm talking about (it has pianted silver dots on it; not white like I said). The wire through which I am getting a reading of about .99 volts is definitely the accessory wire from the harness that plugged into the oem stereo, which the previous owner cut to plug into a new HU (that worked beautifully when I got the car a few years ago, but has since died). I'll have to check the forums on the gauge cluster issue (which I've been meaning to do anyway). That, the + battery terminal (and related wiring described above), and new spark plugs/wires are the only electrical variables that have changed since I had a working stereo (with no external amp). Could I have fried that red harness that screwed onto the positive terminal? I don't even know what that thing does. I was careful, but did the job with a way overpowered iron that has only one setting.
