Postby
Helium2 »
https://forums.nicoclub.com/helium2-u192212.htmlSat Feb 09, 2019 4:00 pm
2010 SL 75K
Recently the lower of the two horn tones started working only sporadically & now it's dead.
This makes the sound less noticeable and bothers me, anyway.
What causes this and what are my DIY repair options?
Postby
amc49 »
https://forums.nicoclub.com/amc49-u275146.htmlSun Feb 10, 2019 1:33 am
Look at the pic of first link and the small screw directly below the nut that attached the wire in dead center of the horn. That nut may be the adjustment nut for the inside diaphragm, it is used to adjust the diaphragm to again make noise. Wear and age can make the setting drift slightly and lots of times just moving the screw a little bit brings the horn back to working. Past that rusted or bad connectors like said. Sometimes you have to break into the case and fix corroded breaker points and commonly fixes things too but the major problem there is once horn is working you have to figure out how to seal the case back up to not leak water.
I used to fix like 7 out of 10 horns, most of the time they can be brought back to life.
