DrIft Ready wrote:I belw the head gasket on my ca18det last week.. fixed everything but wont start... i know what im doing.. so... didnt change any wireing.. only have spark out of #1 & #4 injector is fireing.. nothing else.. have a few friends with runing CA's so i switched every over.. only thing that worked was changing the harness.. started frist try... plese help.. i opened up the harness and checked everthing.. nothing looks wrong... any ideas???please hlep!!!
Did you check the codes on your ecu to see if it has picked-up some trouble in your electrical system's performance. You say you checked everything, but you seem to have forgotten to check the most important thing.
Dee
