centralcoaster33 wrote:Well, I took a look at mine. Most of my white heavy wires actually have a red stripe on them. I do have one from the 75 Amp fuse for the alternator though. I didn't trace it with a voltmeter, just visually. I appears to go down into the sub-harness for the Transmission/ Starter/ Alternator and then it goes to the large bolted on alternator wire. No surprise I guess, since it's the Alternator fuse. Is your alternator grounded? You should have the heavy wire that bolts on, a smaller yet still heavy wire in black for the ground on the alternator chassis and a plug with smaller wires for the thinking part of it all. I hope that helps. There's always the wiring diagrams in the FSM.
Correct, there is a thicker black wire grounded on the alternator then a white wire that connect to the big bolt and then the 2 prong connector. My issue is that the white wire on the big bolt of the alternator that comes off of the lower harness is not a power wire lol I tested it. But the white wire coming from under the fuse is powered. if I knew how to send a picture I would. There's a wire that runs to the positive terminal of the battery...goes down under that fuse.. comes back out from under the other side of the fuse (white wire) and it's getting power. Not sure if I take off the one that's from the lower harness and attach that one or what.
