one very or kinda stupid question.
pancho y onions
Car: 1992 240sx se
ok this is my question....it goes. know i am not stupid but......any ways.i am going from auto to manual. but i cant find the drain plug for the auto oil. or do you have to take out the pan. and if you do how can you do it with out making a mess. i am using my freiand dads shop. i know its kinda dumb but for some reason i cant find it or the 89 model didnt come with one. ok know you can start making fun of me. BRING IT ON.....but please help.
naed240sx
Car: .....
go to autozone and buy a new one.
pancho y onions
Car: 1992 240sx se
what do you mean go to auto zone? i dont need to buy any thing i want to know how do you take out the oil.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
pancho y onions wrote:....it goes. know i am not stupid but
Wait, you mentioned yourself not being stupid. That sentence typed correctly would be, well it couldn't be because it is a sentence fragment, but it would be typed correctly: "No, I am not stupid......."
Ok, back to the point, are you looking for the drain for the transmission fluid? Oil pan? Transmission? Auto to manual? You're just skipping all over the place, retype your question to make a little more sense and you might get a sensible response that can help you.
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
hard to believe, but I actually got what his question was. Yes, there is a possibility that you have to remove the pan to drain the oil, some autos have that. I wouldnt know cause I only drive stick.
Another alternative would be to disconnect the driveshaft, unhook the header from the cat and remove the transmission mount. This way, you can tilt the motor (SLIGHTLY) just enough to drain it from the tail end of the transmission.
-R
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Some of the earlier nissan auto trannies (up to 92?) lacked a drain plug on the pan, so your not missing anything obvious or anything like that.
Just pop that pan off, and change the filter while you are at it.
Edit: see that you just want to remove it, dont worry about draining the fluid just pull it.
pancho y onions
Car: 1992 240sx se
well thinks i knew i ahd to do this. i am knida bad at my grammer not the smartest person in the world any ways. if i leave the oil in wont the oil start coming out of the cooling line when i am trying to take out the transmission. probably will but do you think a lot.
deviousKA
When you pull the lines off, just stick a pan underneath to catch as much oil as possible. Stick plugs or rags over the holes as you remove the transmission/engine. Once everything is unbolted and ready to come out, only takes a few minutes to have it out and on the floor, dont think about it so much.
pancho y onions
Car: 1992 240sx se
ok thinks for your help.
