Yes, there is a way... just need to reprogram your one touch settings!! Happens to everyone atleast once... Lol! Check your manual but basically this is what you do:
You can do two at time... with vehicle on: roll down about half way and stop, roll back up while holding the switches about an extra five seconds (one or two at a time). Repeat for the two rear. The sunroof is similar: open about half way then close it holding the close switch/button for an extra five seconds or so after it had closed... That should rest them all! Try it, if not search for a window reprogramming thread with the Search menu under Infiniti m section...
