One Sided intercoolers for rb20/25?
Cpt_Impossible
Car: G35 6MT
Hey, I waas wondering if anyone has actually tried one of the one sided intercoolers on a rb20 or 25 with the stock IM. They look like the easiest route but they also look like pressure drop and lag would be an issue.
Anyone?
krayton
works goooooood
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Did you buy that from Mckinney?
krayton
Yellow4g63 wrote:Did you buy that from Mckinney?
the intercooler was an ebay special
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
yea i need one asap
themadscientist
A good one-ended chilly should have an opposing end tank that directs the air to make the 180 degree turn as smothly as possible, like this HKS unit. Those look about as efficient as a banjo fitting. Better than nothing to be sure but far from ideal. You can drive a nail with a frozen salmon but a hammer works better.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Search "godspeed" intercooler on ebay they have a nice one i might get but, if i get one getting a intake mani would be pointless, get a intaka mani or not too? lol
Chaos the Xile
Car: 1974 Datsun 260Z
themadscientist wrote:A good one-ended chilly should have an opposing end tank that directs the air to make the 180 degree turn as smothly as possible, like this HKS unit. Those look about as efficient as a banjo fitting. Better than nothing to be sure but far from ideal. You can drive a nail with a frozen salmon but a hammer works better.
BLITZ makes an intercooler like that, its more common than the HKS one, I see the BLITZ on eBay every now and then... complete kit too!
Shahee1
Car: 1993 240sx w RB20DET
I have an intercooler like the Godspeed but the core and the end tanks were purchased separate. My core is a spearco ... it flows really well and boost kicks in fast. Pipes are much shorter also.
Shocker
Car: 89 240sxHB rb26/30
RB20DETodd wrote:Search "godspeed" intercooler on ebay they have a nice one i might get but, if i get one getting a intake mani would be pointless, get a intaka mani or not too? lol
basically the same identical one im running, works awesome! response is basically the same as the stock side mount, i only needed another 4 feet total of piping to actually make it work!
themadscientist
the bar and plate core is sexy
Cpt_Impossible
Car: G35 6MT
My concern with the godspeed one which is also used on many 1g dsms by dejon and road race, but with the way the s13 is:
There isnt really any room under the mouth on the pignose. After the mouth, its bottom of bumper like 1/4 inch, then air... To make the core right in the mouth of the car, you would have to have the IC hanging underneath the body which is no good for business. It just looks really hard to mount and have optimal cooling in the stock s13 bumper.
Anyone have pics that show otherwise?
Shocker
Cpt_Impossible wrote:My concern with the godspeed one which is also used on many 1g dsms by dejon and road race, but with the way the s13 is:
plenty of room.
Cpt_Impossible
Car: G35 6MT
Can you get a pic of straight on in the mouth? To be optimal, I would want all of the core showing with no room for air around it.
Also it looks like the 91-94 style bumper has more room below. It doesnt look like you are utilizing that room though, but with the pig if I put the core right in the mouth, the end tank would have to be cut through the bumper.
Cpt_Impossible
Car: G35 6MT
This is what I am trying to avoid...
Shocker
you cant use the entire opening do to the fact the side/end tanks hang down 3 inches lower than the actual core, if i was to place the entire core in the mouth my side/end tank would hang only a few inches from the street.. id rather not do that.......... also most ppl cut their front bumper up higher so the opening is larger... id rather keep the sleeper style...
Cpt_Impossible
Car: G35 6MT
But the end result of not putting the core in the airflow is an intercooler only working at about 70% efficiency.
Cpt_Impossible
Car: G35 6MT
Krayton,
Did you notice any lag over the stock side mount? Or did you ever use the side mount to begin with? Have you noticed any drawbacks to using the dual pass style?
krayton
Cpt_Impossible wrote:Krayton,
i orginally had a fmic and ran the over the radiator setup. i didnt notice anything really. but at the same time installing that, i also turned up the boost and tuned for 340.
so cant really say for sure.
RB20DETodd
Shocker wrote:
plenty of room.
mmmm thats nice, time to ditch my bandwagon 24x12x3 fmic and get one more functional for my setup.
IowaRB240SX
Car: 1991 Nissan 240sx
I will sell mine. It is a McKinney. Or trade it for a brand new(quality, not cheap) straight thru style. I am building a race manifold and no longer need the same side intercooler.
