98240 »
https://forums.nicoclub.com/98240-u35691.html
Sun Mar 12, 2006 5:36 pm
One of the 4 prongs or what ever you call it broke off and is floating somewhere can that cause it to make me add fuel since it could be blocking something? The stock injectors worked perfectly fine until I put the safc in. Even with the stock injectors that worked fine before the turbo process now work like crap. So I changed the injectors to 370cc and they work the same as the old ones other then my a/f is at 13 but I am still adding fuel before boost. I will put some injector cleaner in to try to clean them and see what that does but I do not think that the injectors are clogged. I will check the safc wiring again to be sure it is wired right, but I know it is I checked it 5 times already.
My wife was driving behind me and said there was some black smoke coming out the exhaust. I think that was when I changed gears.
Is it possible that when I lifted up my motor to take my oil pan off I messed somthing up? I lifted the engine as high as it would go, then a few more pumps to get it a little higher.
On all the safc tunes I seen on nico they were all tuned in the negative numbers. Is this how it is suppose to be or are you also suppose to have positve numbers? This is just so I can get a ideal on how my tune is suppsoe to be.
Modified by 98240 at 7:55 AM 3/13/2006
