ONE POWER OUTLET QUESTION
stone
Car: ROGUE
How can I change the OUTLET power supply from fuse box.
After shut down ( switch off) keep the outlet power on.
for my car refrige use after I parking.
philipa_240sx
Hello stone and welcome to the NICOClub Rogue Forums.
To answer your question:
The Rogue uses a battery protection system that turns off most of the power 5 minutes after the engine is shut off. You simply cannot easily rewire the fuse box or change fuses to get around this. The simplest solution is to run another power wire directly from the battery. Don't forget to install a fuse to protect the wiring and prevent an electrical fire!
stone
Car: ROGUE
philipa_240sx wrote:Hello stone and welcome to the NICOClub Rogue Forums.
:confused: Thanks.
Honva
Car: 2012 Rogue SL AWD
A refrige is going to drain your battery fast. After a few hours, you may not be able to start your car. Get something like this to power the refrige.
http://www.amazon.com/Duracell-DJUMP-17 ... B000U0JCTU
It will safely power the refrige and will recharge when you are driving. Also, no mod to your car is needed.
Return to “Rogue Forum”
