One of the cheapest, best mods ever
Deadrodent
Car: 1992 240sx hatchback
Replace the factory rubber hose that runs from the wastegate actuator to the factory pipe that runs to the throttle body with a hose with the same dimensions.
the factory hose has a metal restrictor inside it that limits the boost to ~7psi.
with the new hose you will boost ~10psi
this mod cost me 2 dollars and my car is significantly faster.
jjisguilty
Car: Zenki S14
with my boost controler off, I can get boost to 10lb's. I had replaced that hose but I thought it was just increases from intake and exhaust. Hmm. learn something errr'day.
Deadrodent
i didn't believe it either at first until i cut open the hose. there is a thick metal hose type dealie inside the rubber hose that signicantly limits flow through the hose. it's about 8 inches long.....THAT'S WHAT SHE SAID
notslow
Car: Nissan Sileighty
thanks for the tip, will give er a shot when she is out of the paint booth.
infamousbz
Car: 1990 240sx hatch
Can you post some pics please?
