one of the benefits of having a messy garage and no memory
themadscientist
Haltech E8 order just placed.
boost_boy
themadscientist wrote:Haltech E8 order just placed.
Smart move!
Dee
Bwana
Car: Denali
Dang Mike, pure craziness man...
I like it.
AWDB12wagon
Car: 1989 Nissan Sentra 4WD
float_6969 wrote:LOL, I know! I know! The TMS owes me big for my little discovery. But until we're sure everything is savvy, we're not gonna let the cat out of the bag....
It has to be anouther nissan crank, things like this have been done, not in the CA, but in the QG. Travis, Unlucky on http://www.sr20forum.com , put an SR20 crank in a QG25 and de-stroked it. Makes a sweet little high reving motor, w/o the crank being a piece of crap like the stock QG is. Once she's built, revving happy, I expect some updates!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah, I am going to need some info on what exactly is needed to retrofit this sweet-a$s full counterwieght crank into the bottom end of my little CA. I know its been done, but a full in-depth writeup is necessary. I'm gonna have to save it for when I nuke the bottom end on my motor though, as I dont have the time or funds to support this (though sweet) right now.
Buddyworm
I know I'm pretty new around here but you guys gotta hurry and figure this out. How close are you? The suspense is killing me.
themadscientist
I progress, that is all
tnslide80
Car: 1991 sil80 (ca in progress)
nice find all i can find is my half done ca and a lack of cash and time.....keep us updated on this ca godzilla build... and u should tell all ur secrets!!!!
themadscientist
You don't want allmy secrets
AWDB12wagon
Take a toke, and cough up the info!
float_6969
I'll tell you when you bring back my valve spring compressor! LOL
themadscientist
Things continue to move forward. I have hit no obstacles that would trigger an abort yet. No worries. Just wish I had more money, this thing ain't going to be cheap
themadscientist
I am not using a CA18 block with my crank but I knew people would ask so I checked if it would work. In a word NOPE! I am not sure what issues if any people encounter when stroking with a CA20 crank but this sumbitch isn't going into a CA18 block without massive amounts of clearancing.The counterweights hit the pan rail webbing at about 30 degrees before and after TDCEven if you decided hacking away at these support structures was a good idea and the crank was able to swing a full 360 the minute you bolted the rods on you would be back to zero. The rods hit the bases of the cylindersSo you again start weakening the block more cutting out the clearance in the bottom of the cylinders. Oh wait, the CA18DET main cap girdle is now in the way, do not pass go, do not collect big stroke. How much clearance do you need? About this much!So yeah, I guess if you were hellbent to get the beast in there you could but IMO the extensive work required and the resulting weakening of the very foundation upon which the entire engine relies on to do seems pretty silly. If you want stroker CA18 use the CA20 crank and deal with those issues.
Masterdebater
Car: 1989 nissan 240sx coupe
what other block can u use tho? or is that confidential too =|
themadscientist
themadscientist
head is back from round 1 at the machine shop. I am using bigger than normal head bolts to secure the four port head on this sucker.
In order for the heads of the bigger bolts to make down into the pocket I had to have the pocket bored up.
The bigger bolt shanks also require the holes be enlarged and the step bore for the head dowels to be similarly punched up.
Enjoy
AWDB12wagon
Why not just use ARP?
AWDB12wagon
float_6969 wrote:I'll tell you when you bring back my valve spring compressor! LOL
Just saw this! I will most likely be up there next thursday, what are you doing thursday? I'm gong to pick up my head from Prather Racing. Let me know bro!
themadscientist
because these are beefier for one. The CA18 uses M11 bolts, these are M12. The ARP studs are listed as "undercut". If this means the shank is stepped down at the threads for the nut then I would doubt they are really that much better than a stock CA18 head bolt.The more important reason is my block has M12 bolt holes so stock CA18 anything is too small. More thread contact area with the bigger bolt combined with increased head torque figures the bigger bolt allows nets me superior head sealing which is important. I will be running an 85mm bore so the meat between the cylinders is sparse, I need as much sealing force as possible.
r34 gtr
Are you having to get completely custom pistons? or does someone actually stock a forged slug for the ca20 block?
Whats the way you do it again? CA20 block and crank, dual cam ca18 head and crank girdle, rb crank timing gear, mitsu 4G rods, uh..anything im forgetting? I mean, Ive seen it done but its been a while.
themadscientist
If I were using a CA20 block. The pistons will be off the shelf forgies and the rods custom. I am trying to keep custom parts to a minimum.
r34 gtr
ah word. Forgot about that, and checking the previous page seemed like too much work at the time. My friend had to get custom CP pistons for his h22/f22 honda project and he said it was quite the pain to figure out exactly what he needed.
themadscientist
I have a nightmare where I drop 8 bills on custom rods and watch in terror as my pistons pop up out of the bore on the first spin around because my math challenged *** didn't carry the 1!
Masterdebater
ooh ouch carrying the 1...that one always gets u in the end... :/
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
fj?
themadscientist
If I could get a CA head to bolt onto an FJ I would have my brain bronzed.
ca18datsun510
you didnt say the crank and block are from the same source.
themadscientist
ca18datsun510 wrote:you didnt say the crank and block are from the same source.
sure didn't . The only part I have definitively identified is the four port CA18DET head.
ragenasian
Car: AE86 w/CA18DET
This is killing them isn't it Mike HA HA
themadscientist
I must admit, I do enjoy the palpable frustration. It's almost as bad as the way I felt when I realized the rod was wrong.
