one of kind ca18det swap for sale. turn key ready to drive or race.
teambuiltnissan
Car: nissan 2 dr
I am decide to put another engine on my 240 next season. so my engine set up is up for sale. I have another ca18det that I am building so either way I will keep making fastest ca18det.
Engine
83mm CP forged piston with custom trick rings
Pauter rods with rod bolts
OEM bearings (main, thrust, rods)
OEM crank balanced with polished
Tomei 1.2mm metal headgasket
ARP head studs
Tomei valve single coil valve springs
Tomei 270 duration with 8.8mm lift cams
Tomei adjustable cam gears
High volume oil pump
Yellow Munson porting and polishing
Intake
Yellow Munson custom sheet metal intake with Q45 90mm TB.
Turbo
T04R BB with .69AR on center housing
Streetdynamic custom 3 inch down pipe with mid pipe.
Twin Tial 38mm wastegate with 18psi springs.
Twin 50mm Tial BOV
Custom 4" intercooler
Fuel
yellow munson top feed fuel railPrecision 1000cc injectors
Electronics/ECU
Yellow Munson CA-SR wiring conversioncomplete wiring harness for s13
SR20 Apexi Power FC D-Jetro
serious offer at [email protected] dee. I hope this add would be ok with you.. if not email me..
catchumdaylee
Car: any thing fast
scott you should also post on drag240sx let me know what you want for the SR20 Apexi Power FC D-Jetroi may have a customer that will want it
-donnie
boost_boy
Not a problem, Scott! And good luck with the sale. Also, I look forward to seeing what you have been preparing (even though I have avery good idea ).
Dee
BACARDI_DWB
just for the sake of question what kinda power were you putting out? with 1000cc injectors i am assuming 500hp+ and what kinda times were you doing? mph?
teambuiltnissan
Car: nissan 2 dr
1000cc injector is running 100% of duty cycle at 7200rpm on 2nd gear thro whatever gear. on 25lb of boost. time slip on top of this section
ZERO_HOUR
email sent
teambuiltnissan
Car: nissan 2 dr
I might consider sell whole car. if someone is interested.
turnkey 10sec car.
email sent back
BACARDI_DWB
pics of car? just for pleasure sake
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
catchumdaylee are you active on drag240sx.com? Speedsex?
Teambuiltnissan is yellowmunson on there.
Im koukimonster, i think ive talked to you about the manifold before.
