yokota180sx wrote:or you droop to much, you hit a big *** bump, spring comes unseated on the up stroke and sits sideways on the damper shearing the shaft
That's never happened to my D2's, even through such cities as Boston and NY. My Konis have about 2-3" of completely unloaded droop, and the car was well- composed (well, as good as it gets for 11kg springs up front) on NYC potholes.
I'd like to reiterate:
AceInHole wrote:On rebound/ droop, if the damper itself can't retain the spring (i.e. keep it seated) while driving, then it's obvious it isn't valved well enough to control the spring.
I'd expect the spring to unseat if the rebound stack on the damper piston is blown, or if the gas charge is dying off. If your springs begin to unseat, take your dampers in for service. Most of the cheap coilovers on the market fill with normal schrader valves, or have a 1/8 NPT fill fitting that you can replace with a schrader. If that doesn't fix it, you need a major overhaul, which most companies remedy by sending you a new unit entirely (showing you how little the dampers are actually worth).
nieko wrote:i love how people always try to prove yokota wrong and then they get owned right back
I stand corrected. I should have rephrased it: The only reason to run preload is to keep your piston and floater within the recommended operating range of the damper body or if your dampers are inadequate and blown.
Thanks for the correction.
