Lost_To_A_K-Car wrote:An LSD will eventually wear out. Unless you can get a factory one with fairly low mileage, don't.
The LSDs in all Japanese cars are all made by the same company, a subsidiary of Hitachi.
OK, a VLSD will NOT wear out. the parts dont touch, and Im not sure but I think(although you might be right..) there are different LSD mfg in japan....a VLSD works by heating up silicone fluid, not via a clutch-type action(which are the ones that CAN wear out).
it would be very tough to wear out a VLSD man...like in the "even racing it'd be ****ing tough" range...anyways, the 2 way LSD will be great if your michael shumacher or something....IE its great if you know how to "use" it, and things, since it will cahnge braking into turns drastically, and change things when acellerating out of it...from what I've heard it makes the car super touchy....
-chet
