Same here. Its leaking oil enough to make my oil go low. I didnt realize it was leaking, so I dont know how long this has been happening.Redline240 wrote:I lost the center one on back, ever since it's been leaking a little down the back of the engine and on the transmission...gonna replace it while its off the road...
Redline
Are you sure that's your only leak? I find it hard to believe you're losing that much oil from one valve cover bolt. Like I said, it's not like the oil is under pressure at that gasket.Neejay wrote:
Are there any clamps or anything to help out?
In a nutshell, you drill out the hole, tap it, thread in the spring-like insert and there you have it. You've got something to thread that bolt in (the coils) and it'll be stronger than the way it was before it got all ****ed up.Neejay wrote:Yeah, if you could see the oil residue where I guess I stripped the bolt, you'd understand. You can see the oil seeping from valve cover.
And I tried to research a little bit on helicoil...but how the hell does that work?
Except that a ziptie would provide basically zero compression. Each bolt puts down over 1000 lbs of clamping force on the cover against the head. I agree that missing a single bolt shouldn't lead to an immediate leak. If it does, then the gasket probably wasn't in very good shape to begin with.BadMojo wrote:Anyway, I suppose you could uhhhh...use a zip tie. I guess it wouldn't melt.
Its a fairly new gasket. But Im missing one bolt, and another one (or 2) are stripped. So does that mean the screw is stripped, or the hole?DAEDALUS wrote:Except that a ziptie would provide basically zero compression. Each bolt puts down over 1000 lbs of clamping force on the cover against the head. I agree that missing a single bolt shouldn't lead to an immediate leak. If it does, then the gasket probably wasn't in very good shape to begin with.
Yeah, overtorqued bolts would easily do it. If you've ever looked at the torque specs for the valve cover bolts, they're very low. Aluminum is pretty damn soft compared to the bolt you're putting in there, as Daedalus said. It's pretty common, I think.madbouncy wrote:What usually causes this? just like overtorqued bolts or would it just happen over time? When I pulled out the bolt it had all the shavings on it and there was some alluminum in the bottom of the bolt.
