hockalougie »
https://forums.nicoclub.com/hockalougie-u23391.html
Tue Aug 04, 2009 4:16 am
My high school Q45 is no more.
I drove a 1991 Infiniti Q45 through high school, we bought it with a blown engine in 2004. We replaced the engine twice (first time we didn't know about the chain guides and it ate it in about 1,000 miles) had about 80k when we bought it, traded it in with about 118k.
It was traded in under the Cash for Clunkers program, so if you are sensitive about your Infiniti, don't read the following.
Upon trade in, we got a $4500 credit towards the purchase of a new vehicle, a 2009 Chevy Cobalt for my brother. The appraised trade-in value of the car was $400, so we got a pretty good deal.
The day after, the dealer drained the oil, put two quarts of a mixture of sodium silicate, sand, and water in the crankcase, and fired it up. Ran it at two grand until it seized. Afterwards it was sent to an automotive recycling facility, where it would be later crushed. This is required by the CARS program to prevent the vehicle from being resold.
What makes it okay: This Q had lots of problems. It recently just started to fall apart and it seemed for every one thing you fixed, three things broke. It was on it's third engine, and developed a miss that couldn't be diagnosed, and then developed a crack in the head at 114k. The transmission lost overdrive at 115k, and then lost first at 117k. It had loads of electrical problems towards the end. Tail lights would suddenly stop working, sunroof and windows would be stuck open, and the A/C worked intermittently. Even the driver's door lock had worn out. The brake pedal would randomly drop to the floor in regular driving. The steering was going out too, so when you turned right corners the steering wheel wouldn't return to center for a couple miles. We pumped thousands and thousands of dollars into this car, and were very faithful to her, but she just completely fell apart. All these problems started to turn up at around 110k. Then she failed emissions. That was too much to bear. A car that did not want to be fixed and now could not be driven legally. It was time to say goodbye to the battleship...many memories in that car.
