Empty V wrote:
The two-in-one only lights up the single passenger window switch, the top LED on the switchpack lights up the lock/unlock switch. I used 5mm 15* LED's with the stock resistors and they work great, almost too bright @ 5200mcd. I didn't measure resistance on anything just threw them on to see what would happen. I know at each LED I'm getting a little over 2V though.
Last night I noticed on my driver's side I lost one of the 5 LEDs so I'm going to pull it apart and see if the solder failed or if I need to add/change a resistor because they're running too hot. When you did it did you install larger or smaller resistors?
Thanks for the help as usual!
Billy
Ok, I'm stupid for not reading the post properly, for some reason I thought it was the driver switch pack and not the passenger switch pack.
So I would just replace the two-in-one LED with a single LED. I'm assuming that on your driver switch pack, each switch has its own separate LED. If that's the case, then for uniformity I would just use a single LED on the passenger switch pack window switch. You can just solder the new LED across from trace-to-trace. I do see one thing that might be a problem; the resistor in series with the factory LED's says 511 on it, which probably means it's somewhere around 500ohms. If that's the case, then you may need to increase that resistance so that you don't blow the new LED.
If your battery puts out less than 14V (say around 12-13V) then you should be fine and you should just be able to solder in the new LED without any problems. Do you have a link to the page where you got your new LED's from (or the LED's specs)? Also, what is the maximum voltage your battery puts out (the highest voltage whether car is off, in ACC, ON, or running)?
I also had an issue with my passenger switch pack, the factory resistance was far too low for the new LED's so I had to solder in a new resistor in series with the LED. This was a huge pain since I had to physically cut the board trace and then solder the new resistor in.
