One last vacuum problem on the CA.
Token
Car: 1990 180SX
Alright, got everything installed and ready to go but I'm having one last problem with a vacuum line. If I plug it up when its starting, it'll start fine, when its not plugged, it won't start. Once everything gets all warmed up I can plug it up and no more boost leak.
Anyone know what this is supposed to be routed to?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
looks like a line for the secondary butterfly system(vac line), but I could be wrong. I never got the stock IC piping so dont qoute me.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Goes to AICV? Whatever the big round gray solenoid thingy next to the thermostat housing is.
rico05
Car: 1992 RMS13 w/ CA18DET
Goes to the air regulator.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
yeah, that's the air that feeds the idle circuit. It should t-piece to the pipe that feeds the idle control block, and the other end pushes into the cold idle valve under the throttlebody.
If you connect it up properly and the car doesn't idle..then the idle control block needs adjusting and/or cleaning.
r34 gtr
Yeah, that thing. Whatever its called. Damn CA has so many idle air thingys.
rico05
dattodude wrote:If you connect it up properly and the car doesn't idle..then the idle control block needs adjusting and/or cleaning.
Or replacing the regulator. I used one off of a B13 SE-R (SR20DE). $70 online. Or you can buy one for like $80 or so from a parts house.
Token
Car: 1990 180SX
dattodude wrote:yeah, that's the air that feeds the idle circuit. It should t-piece to the pipe that feeds the idle control block, and the other end pushes into the cold idle valve under the throttlebody.
Got it, thanks guys.
